Page 35 of 42 FirstFirst ... 253334353637 ... LastLast
  1. #341
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 12 Hours Ago Has been a member for 8-9 years. Has a total post count of 472. Received thanks 75 times, giving thanks to others 22 times.
    Yes, got to be worth waiting for the right one. Buy in haste, repent at leisure etc. If you buy a heavy old dog you will be stuck with a money / effort pit.
    The Shizuoka didn't sell for the starting price so I contacted the seller and suggested something more workable and he went with it.
    I've seen people make a hole in the roof to make room for a taller machine.....
  2. #342
    Chaz's Avatar
    Rented house :-( Otherwise Id have no problem 'fixing' the roof.
  3. #343
    Muzzer's Avatar
    As John says, converting a Bridgeport isn't really the best way to go. I'm also part way through doing one myself (I was doing it when I had the accident with the mouse on ebay) and their construction is nothing like a pukka machine. Having said that, there are quite a few BP-type CNC machines that were made as CNC from new, not just the Interact type. Get one of those with ballscrews, servos etc and fit a modern controller.
  4. #344
    Chaz's Avatar
    Thanks, how do I know which ones these are? I dont have the experience / knowledge? Is anything previously 'cnced' worth looking at?
  5. #345
    Muzzer's Avatar
    I would say if it's been fitted with servos and a CNC controller from new, it's got to be a good candidate. Could be worn out of course but a lot of the work will have been done for you even then. If you spot one of these with an old controller, it may be a good price and not hard to update. The X and Y servos (and belt drive covers) are easy to spot. If it's only 2 axis, you can do the Z axis yourself.
  6. #346
    Chaz's Avatar
    Thanks, have seen a DIY solution for Z where the machines are 2 axis only. One of these (bridgeport or clone), worth looking at then?
    Ive got Thor for aluminium but would like something for steels or larger work area.
  7. #347
    Chaz's Avatar
    This is perfect but cant get a response from the seller - https://london.craigslist.co.uk/tld/...611374089.html
  8. #348
    Muzzer's Avatar
    Generally on a quill machine the Z axis is done by driving the quill through a yoke attached where the feed stop used to be.
    Have a look at what I've been doing - some CAD models here https://mightyshiz.blogspot.com/2018...on-z-axis.html
  9. #349
    Chaz's Avatar
    Thanks, appreciate sharing this.
  10. #350
    Muzzer's Avatar
    That looks pretty nice. Seems remarkably cheap. If it is all there, sounds ideal. Even if it's not working it might be worth it.
  2. Manual autochanger problems.
    Last Post: 05-02-2015, 01:14 AM
  3. WANTED: Centec 2A manual
    By Web Goblin in forum Items Wanted
    Last Post: 03-09-2012, 09:56 AM
  4. Translating the manual
    By Robin Hewitt in forum Moulding Machines
    Last Post: 01-09-2012, 01:21 PM
  5. Bridgeport Conversion
