    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 3 Hours Ago Has been a member for 8-9 years. Has a total post count of 483. Received thanks 81 times, giving thanks to others 26 times.
    Not sure where you get the 32mm figure from. The yoke bores are designed to take bronze cylindrical leadscrew nuts, as opposed to being directly threaded. On my Series 1 BP clone, the original X&Y leadscrews were 1-1/4" ie ~32mm OD. The actual leadscrew nuts themselves were pretty much 39mm OD and the DFU2505 ballnuts are 40mm OD, so I only had to bore the yoke bores out about 1mm on their diameters.
    As for fixing, there's really no need to use all 6 holes. I only fitted two M6 screws and there was enough meat for me to drill and tap the holes. If you look at the tensile load that would cause an M6 bolt to fail, you'll see that this wouldn't be the first link in the chain to break.
    Here's a bit about the actual boring: https://mightyshiz.blogspot.com/2018...or-larger.html
    And fitting the thing back on the machine. Note that the Y axis ballnut may foul something (I forget - possibly the knee lift?), which required some angle grinder action on mine.
    https://mightyshiz.blogspot.com/2018...allscrews.html
    Murray
    Murray
    Excellent thanks Murray I appreciate the work you put into documenting that. I'll spec the end machining myself as my drive arrangements are a little different to yours and whilst I'm waiting on China Post will bore out yoke.
    Yup 32mm was a mistake on my part.
    Never used a faceplate before fortunately one came with my Triumph lathe so it promises to be good fun.
    David
  2. Manual autochanger problems.
    Last Post: 05-02-2015, 01:14 AM
  3. WANTED: Centec 2A manual
    By Web Goblin in forum Items Wanted
    Last Post: 03-09-2012, 09:56 AM
  4. Translating the manual
    By Robin Hewitt in forum Moulding Machines
    Last Post: 01-09-2012, 01:21 PM
  5. Bridgeport Conversion
