12-05-2016 #9
Ok, but by building a custom Z-axis and mounting it on the rear of the ram I would retain whatever travel I build into the new axis, it means swivelling the ram round to change from heavy to light milling but thats about it, plus would need two z-axis drives - heavy and light.
The Z on the heavy side is a pain, a couple that i have seen today - one replaced the quill lever with a toothed pulley and drove that via a planetary gearbox reduction - seemed ok, another replaced the fine-feed hand wheel and drove that, the ones that mount to the front of the quill I am not too impressed with, have read a few tales of quills being trashed by the single bolt pulling out.
As for speed, so far most of my mini-mill work ranges from 600mm/min to 150mm/min - hardly blistering, I'm sure the old girl can match that ;)
I think this may be an interesting project.
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
