22-05-2016 #11
Thats £300 extra for what.? Ridgid tapping that you don't need.! Indexed postioning you don't need because no ATC.!
Controller will give you every thing you need regards speed control etc from G-code using VFD just like it would if Servo so don't see the point.
Only advantage I see is the indexing and possibly extra torque at lower speeds, but you have back gear so not problem.
Save the Dosh and spend it else where.!
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
