    Looking better...
    Got the knee painted too.
    Hit a block now - turns out the knee-lift screw bearing is dead, got the deadly silver paste coming out of it and feels like a bag of nuts. Will have to order one from somewhere but cant reassemble until i get it :(
    Got most of the big stuff stripped , sanded and painted now. Started putting a few little bits back on but cant do much until i get the new knee lift bearing.
    Found an issue with old lube system - this is the feed to the saddle...
    Olive was cocked and tube crimped, probably wrong size olive for the pipe :(
    Moving on....
    Motor mount plates for X & Y axes.
    Is it better to hang the plates from the four bracket mount screws or the three bearing retainer screws?
    Using the four screws would mean a much larger lump of metal is needed to span the width, I won't be refitting the dials so using the three mount screws probably won't affect anything.
    Any thoughts?
    Go off the plate:
    I made a spacer and clamped it all there.
    My Y axis one looks like this:
    I bought proper angular high spec contact bearings for the screws (+£250) and some very fancy face locking lock nuts from Germany.
    https://emvioeng.com
    Very nice :)
    Have you any more pics, looking for ideas on homing/limit switches etc
    I had not thought of putting the Y motor to the rear, all the builds i have seen have it hanging down low beneath the handle, it will have to stick out though as my motor is too long to tuck under.
    Dave, I have mounted my limits off of the newall DRO scales but not happy with them. Going to be printing some parts shortly to fix the issues and will post.
    Ok, I am only using the Mach DRO's - my Sino DRO kit will be sold to raise funds, can't really see the need to have two DRO systems.
    Yes, with the CSMio you can get away from the extra DRO. I have it becuase I am using steppers and a smoothstepper but also have a very cunning plan there too.
    What kind of switches are you planning on using?
  2. Manual autochanger problems.
    Last Post: 05-02-2015, 01:14 AM
  3. WANTED: Centec 2A manual
    By Web Goblin in forum Items Wanted
    Last Post: 03-09-2012, 09:56 AM
  4. Translating the manual
    By Robin Hewitt in forum Moulding Machines
    Last Post: 01-09-2012, 01:21 PM
  5. Bridgeport Conversion
