    Ok, I am only using the Mach DRO's - my Sino DRO kit will be sold to raise funds, can't really see the need to have two DRO systems.
    Yes, with the CSMio you can get away from the extra DRO. I have it becuase I am using steppers and a smoothstepper but also have a very cunning plan there too.
    What kind of switches are you planning on using?
    https://emvioeng.com
    Quote Originally Posted by komatias View Post
    I have no idea yet but they will need to be very heavy duty to put up with the mess.
    These are good quality strong, adjustable and waterproof and come in a variety of designs
    http://www.aliexpress.com/item/Water...707482221.html
    Yes, that would my choice, there are a lot of head options - roller, plunger, lever etc with that switch type.
    Need to choose where to mount them sensibly too.
    Got the knee back on tonight, new lift bearing makes it silky smooth after years of grinding up an down...
    Anyone know how to adjust gibs properly? The books just say tighten until you feel resistance but on the knee that could be very tight?
    The vise-grips are only there to crimp off the feed to the saddle so i can prime the way lube pipes ;)
    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Dial/DTI gauge, magnetic stand, and a big lever.
    You don't want to adjust it up to the point there's no measurable play as you risk it binding and no room being left for oil, but you also don't want it flapping about.
    When adjusting slides that I can't try moving by hand to test resistance, I usually aim for around 0.02mm of movement on a DTI. On older machines, you may need to allow for worn areas, so you ideally want to adjust things at the least worn part of the travel.
  2. Manual autochanger problems.
    Last Post: 05-02-2015, 01:14 AM
  3. WANTED: Centec 2A manual
    By Web Goblin in forum Items Wanted
    Last Post: 03-09-2012, 09:56 AM
  4. Translating the manual
    By Robin Hewitt in forum Moulding Machines
    Last Post: 01-09-2012, 01:21 PM
  5. Bridgeport Conversion
