I have read some tales as its a US motor and a bit awkward to dismantle, to find bearings size i would have to strip down which risks disturbing old and fragile varnished wiring etc. Not a big issue but could end up in a trashed motor.
The extended/custom shaft makes replacements a total bugger - practically impossible to fit a new motor and re-use the Reeves vari-speed drive system as new motor shafts are far too short.
This was the reason Bridgeport motors are stupid expensive.
So, options - strip and attempt repair.
Fit a servo and dump the Reeves drive but retain back-gear ?
The budget for this job went silly a long time ago - i was not intending on replacing all the ball bearings etc and some of them are £££ so it seems now that an extra £300 or so on a 3kw servo/drive is pretty irrelevant overall.
The servo would likely be the easiest option - just a new mount plate and two pulleys, the repair on the bearings could be the cheapest option but would still leave an inferior, power-sucking drive system on what is now a damn expensive machine.
I'll work some prices out.Last edited by Davek0974; 24-06-2016 at 05:28 PM.
24-06-2016 #2
24-06-2016 #3
These would be ball bearing races so not repairable in that way.
24-06-2016 #4
24-06-2016 #5
I'm losing the plot here Boyan, I'm talking about the bearings inside the 1-1/2Hp spindle drive motor are buggered. ;)
24-06-2016 #6
Drop-plates for X & Y servo motors - 10mm, 12mm, 15mm thick ally??
24-06-2016 #7
Thicker will be better, but it will depend on servo shaft length/pulley thickness as to what's practical. Some form of box section would be better/stiffer.
Regarding the motor bearings, unless the motor has some odd wiring/end cap configuration and/or you damage the windings trying to lever the end caps off, stripping it and replacing the bearings shouldn't be a problem.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
24-06-2016 #8
I was saying if it works for removing ball screw backslash and the ball screw is in fact a more complex ball bearing , its worth a try at the cheap price of it. How fast this motor moves? 1200rpm? Same as ball screw.
I see as a better idea changing to cheap Dc motor or better servo motor. And why not a cheap modern normal motor , disassemble, weld some shaft and machine it on place. That would be super simple. And a bracket adaptor
24-06-2016 #9
I'm going to have a go at dismantling i think, try that first.
A 2.0kw AC servo would be best but a toss-up between money and easy-fit;)
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
