24-06-2016 #111
24-06-2016 #112
24-06-2016 #113
I'm losing the plot here Boyan, I'm talking about the bearings inside the 1-1/2Hp spindle drive motor are buggered. ;)
24-06-2016 #114
Drop-plates for X & Y servo motors - 10mm, 12mm, 15mm thick ally??
24-06-2016 #115
Thicker will be better, but it will depend on servo shaft length/pulley thickness as to what's practical. Some form of box section would be better/stiffer.
Regarding the motor bearings, unless the motor has some odd wiring/end cap configuration and/or you damage the windings trying to lever the end caps off, stripping it and replacing the bearings shouldn't be a problem.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
24-06-2016 #116
I was saying if it works for removing ball screw backslash and the ball screw is in fact a more complex ball bearing , its worth a try at the cheap price of it. How fast this motor moves? 1200rpm? Same as ball screw.
I see as a better idea changing to cheap Dc motor or better servo motor. And why not a cheap modern normal motor , disassemble, weld some shaft and machine it on place. That would be super simple. And a bracket adaptor
24-06-2016 #117
I'm going to have a go at dismantling i think, try that first.
A 2.0kw AC servo would be best but a toss-up between money and easy-fit;)
25-06-2016 #118
Well, I spent a good few hours trying to dismantle this motor while being very careful not to risk damage, I could not even get the drive disc off the long shaft, seized well on. There is also a pressed-on fan at the top to shift which would likely bend/break so i carefully replaced what i had done and left it.
So my choice is now to build the cabinet and wire for the VFD / motor OR throw one of these in...
http://www.aliexpress.com/store/prod...037588952.html
I have asked the guy for a 2kw or 2.2kw 3000rpm unit but not had a reply yet, seems the bigger servos don't have the speed needed.
Fitting would be easy, but the only benefit i would really see is the easy and accurate speed control - I don't need/want rigid tapping although i think it would be useful for smaller taps maybe - what is needed to gain rigid tapping?? Is it just a setup option or do i need more CSMIO modules??
25-06-2016 #119
Pulleys/belt - 44t HTD8 x 30mm should handle it ok.
26-06-2016 #120
You'd need an ENC module if you wanted to do rigid tapping.
The motor will most likely run for a long time before the bearings get bad enough to cause issues. If you could get some fresh grease into them, it would most likely make them last even longer and quieten them down.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
