Drop-plates for X & Y servo motors - 10mm, 12mm, 15mm thick ally??
24-06-2016 #2
Thicker will be better, but it will depend on servo shaft length/pulley thickness as to what's practical. Some form of box section would be better/stiffer.
Regarding the motor bearings, unless the motor has some odd wiring/end cap configuration and/or you damage the windings trying to lever the end caps off, stripping it and replacing the bearings shouldn't be a problem.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
