25-06-2016 #11
Well, I spent a good few hours trying to dismantle this motor while being very careful not to risk damage, I could not even get the drive disc off the long shaft, seized well on. There is also a pressed-on fan at the top to shift which would likely bend/break so i carefully replaced what i had done and left it.
So my choice is now to build the cabinet and wire for the VFD / motor OR throw one of these in...
http://www.aliexpress.com/store/prod...037588952.html
I have asked the guy for a 2kw or 2.2kw 3000rpm unit but not had a reply yet, seems the bigger servos don't have the speed needed.
Fitting would be easy, but the only benefit i would really see is the easy and accurate speed control - I don't need/want rigid tapping although i think it would be useful for smaller taps maybe - what is needed to gain rigid tapping?? Is it just a setup option or do i need more CSMIO modules??
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
