27-06-2016 #11
Its all to do with power and torque, from another forum on this setup.....
Quote..
Well the 1.5Hp induction motor with variable mechanical drive would have (basing torque on 1.2Kw)
2880RPM 0.8kW and 3.94 Nm
1440RPM 0.8Kw and 7.9 Nm
720 RPM 0.8Kw and 15.78Nm
The 1.8kW Servo would have,
3000RPM 1.8kW and 5.7Nm
1500RPM 0.9Kw and 5.7 Nm
750 RPM 0.45Kw and 5.7Nm
As you can see, I would be losing a lot of power in the lower ranges but retaining constant torque, what is needed is both torque AND power.
It can be done but i would need to fit a 3.8kW servo to match the existing motor without losing performance, this is too expensive and they only run to 2500rpm.
I have just been advised that the encoder module CAN use the motor encoder ok, as long as the motor and spindle are at 1:1 ratio.
Will refit the original motor.
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
