14-07-2016 #11
VFD control ?
I currently have my fwd and rev signals wired through two relays using the built-in VFD control supply to control itself.
Is this worth it or should I bin the relays and connect the VFD ground to the CSMIO control ground and go direct from CSMIO output to VFD input?
Its a little layer of isolation but also mechanical complexity if not needed.
Safety relays....
The CSMIO manual shows a PILZ safety unit being used, I gather others are just as good? PILZ are damn expensive but other like Telemechanique items are better priced.
I gather they are used because they monitor the main control contactor/relay and also offer forced contact seperation etc internally, any other reasons? Any types to look out for?Last edited by Davek0974; 14-07-2016 at 06:16 PM.
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
