    Z-axis is coming along nicely - got all the parts machined on the mini-mill ;)
    Last step is to make the link from the nut to quill.
    My first idea is to plasma-cut a part from 10 or 12mm steel plate, then fit it up and weld it to original bridgeport part. This would make assembly easy as i can fit the parts up on the mill then clamp together and remove to make the weld.
    Sound like a plan?
  2. Manual autochanger problems.
    Last Post: 05-02-2015, 01:14 AM
  3. WANTED: Centec 2A manual
    By Web Goblin in forum Items Wanted
    Last Post: 03-09-2012, 09:56 AM
  4. Translating the manual
    By Robin Hewitt in forum Moulding Machines
    Last Post: 01-09-2012, 01:21 PM
  5. Bridgeport Conversion
