Threw some panel buttons into the mix today, also fitted LED's for little bling ;)
Video here...
19-07-2016 #2
Why do the other lights come on when press cycle start.? Presume they are Feed hold and Stop.!
Are you turning lights on using Outputs and Macro pump.?
19-07-2016 #3
Yes my thoughts were that when idle the Cycle start and Spindle Toggle would be active and when active the Feed-Hold and stop would be active. The logic is that the lights indicate rapidly what a possible action would be.
I could go one step further and use the lamp supply as the switch source so only the lit buttons would do anything but i think Mach has that pretty much covered anyway.
Yes, I have a small bit of code in Macropump.m1s and an output feeding a relay, the lamps run from the N/c and N/o contacts on that relay.
The macropump code checks two omelette's for run or feed-hold.
Edit..
Frigging autocorrect - that last line should read....
The macropump code checks two oemled's for run or feed-hold.Last edited by Davek0974; 19-07-2016 at 10:01 PM.
19-07-2016 #4
19-07-2016 #5
Nice,
I'm only using the relay as the two lamp patterns are directly opposite each other so i just use both N/o and N/c on the relay. LEDs are 24v but this seemed easier and only used one output;)
21-07-2016 #6
The Z-axis is doing my head in
My idea of welding it together is doomed to failure I think - the original bridgeport quill stop is porous and soaked in oil, any attempt to weld it simply creates a pool of oil and crap welds. I managed to tack it up but that only got me to my next headache....
Alignment is being a bitch - I can't seem to find a position where all the parts just play nicely, there is a fair amount of stress and strain between the screw and the quill, it can be moved up and down by hand but I'm not happy with it from an engineering point of view.
Not sure how to sort this at the moment, a right PITA.
I might just bolt the two parts together and see how it goes, that will allow me to shim things here and there for alignment, seeing the one from Komatias above being held by an M8 screw makes me think this might work.
21-07-2016 #7
Ok, sorted it i think
Couldn't rest without a fix so a couple of hours fiddling and a few thin shims later we have smooth motion from top to bottom, its pretty easy to reverse-drive it by moving the quill lever
The bracket that holds the nut was slightly twisted and the nut hole was too tight, fixing both of those cured the problem.
Now i need to fix up some limit switches and get the motor hooked up.
There are currently 14 users browsing this thread. (0 members and 14 guests)
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
