    The Z-axis is doing my head in
    My idea of welding it together is doomed to failure I think - the original bridgeport quill stop is porous and soaked in oil, any attempt to weld it simply creates a pool of oil and crap welds. I managed to tack it up but that only got me to my next headache....
    Alignment is being a bitch - I can't seem to find a position where all the parts just play nicely, there is a fair amount of stress and strain between the screw and the quill, it can be moved up and down by hand but I'm not happy with it from an engineering point of view.
    Not sure how to sort this at the moment, a right PITA.
    I might just bolt the two parts together and see how it goes, that will allow me to shim things here and there for alignment, seeing the one from Komatias above being held by an M8 screw makes me think this might work.
    Ok, sorted it i think
    Couldn't rest without a fix so a couple of hours fiddling and a few thin shims later we have smooth motion from top to bottom, its pretty easy to reverse-drive it by moving the quill lever
    The bracket that holds the nut was slightly twisted and the nut hole was too tight, fixing both of those cured the problem.
    Now i need to fix up some limit switches and get the motor hooked up.
    Got the switches fitted and have finally achieved 3-axis motion :)
    A short video showing basic path with two tool-changes...
    Scary stuff - she has cut her first steel
    Spent the morning putting stuff back - trammed the head, fitted the vise and trammed that in, fitted a floating Z touch-plate and modified the touch-off macro so it did what i wanted.
    Threw a small lump of 20mm scrap in, a duff 1/2" four-flute cutter and programmed a facing cut in Aspire of 0.5mm, seemed way slower than i would have moved if doing it manually - may not be a bad thing. It gave me a speed of 140mm/min at 650rpm
    Picture below - looks worse than it is, pretty good finish as it goes considering the state of the tool etc. and dry cutting plus unknown grade of steel.
    Next I tried spot-drilling four places and followed up with through-drilling with a 6mm drill, all went perfectly.
    I really need to sort the speed control out though - it tells me when to put it in back-gear or high/low speed so the VFD can give me the final speed BUT it only does this when it gets the S command from the code - it shows the message on screen but the carries on cutting at the wrong speed. What i need is for it to stop the spindle and show the message, wait for me to set the right conditions and the restart the spindle and get to work.
    All looks fine now. So whats next? Mist cooling, right?
    Ha, I already have that built, it's fitted on the mini-mill.
    The next step is to weld up a suitable control cabinet, this is needing a big cab - about 850 tall x 700 wide and 270 deep, commercial ones are +£250 in that size so will plasma cut and weld up from 3mm sheet steel parts i think.
    Then i have to strip the rats-nest down and start the final build.
    I've been running various cutters through HSMadvisor and it seems i've been pushing them quite hard when doing it manually - all the feeds seem very relaxed ;) I tended to run the HSS so the chips were straw coloured and the carbide insert ones just flat out and hard - dark blue chips that melted your shirt ;)
    Got the control cabinet built today, absolute monster and a two-person lift :)
    Fitted the mounting bars too.
    Next job is to strip the test setup down and start final fitting.
There are currently 15 users browsing this thread. (0 members and 15 guests)
  2. Manual autochanger problems.
    Last Post: 05-02-2015, 01:14 AM
  3. WANTED: Centec 2A manual
    By Web Goblin in forum Items Wanted
    Last Post: 03-09-2012, 09:56 AM
  4. Translating the manual
    By Robin Hewitt in forum Moulding Machines
    Last Post: 01-09-2012, 01:21 PM
  5. Bridgeport Conversion
