Page 17 of 42 FirstFirst ... 7151617181927 ... LastLast
  1. #161
    Quote Originally Posted by komatias View Post
    Why not just get a quillmaster or a speeder? Somthing that is inline with the spindle in the firstplace.
    A quill master only gives 2:1 speed up so would give me 6000rpm, no idea of what a speeder is?
    My high speed spindle gets me to 24,000 rpm, still low but very usable on aluminium.
  2. #162
    Some more progress...
    Got the cabinet mounted on the side of the mill...
    Also cut and welded up the pendant workstation and trial-fitted it on its suspension arm...
    Not all the holes will have buttons but thought it best to cut spares and fit blanking plugs.
    Slightly concerned about the strain on the 10mm stud holding the arm on the rear of the ram but it seems ok.
  3. #163
    Dave,
    truly inspiring!
    You thinking of making a flood enclosure for the mill? It made my life so much better when I did.
    https://emvioeng.com
  4. #164
    I think it will need a chip control enclosure but I'm hoping to run mist coolant only.
  5. #165
    Started panel wiring today, one of my favourite parts of a build :)
    Got the grounds and most of the neutrals in, plus the motor supply from the VFD to the terminal bar.
    The space at top-right is for the high-speed spindle VFD - can't fit that yet as its still on the mini-mill.
  6. #166
    You are not putting the output from the VFD onto 3 separate switches are you ?
    If one trips you will fry the VFD.
    VFD has to go to motor with no breaks.
    John S -
  7. #167
    No, no, no ;)
    The output from the vfd goes direct to the terminal bar and then to the motor.
    The three contactors are:- VFD 1 supply, VFD 2 supply and Servo's supply.
    The VFD's are for main motor spindle and aux high-speed spindle, only one will run at any time.
    I think having a terminal bar in between motor and VFD is acceptable.
  8. #168
    Yes that's fine Dave, hard to tell what someone envisages just from a picture
    John S -
  9. #169
    Of course, no worries ;)
    A rough idea of the safety/control side of the wiring...
  10. #170
    Sir,
    Sir,
    Query please?
    You show pin 14 from the XPS as going to relay 1, relay 2 and the coil of K3 but you are also showing K3 across Y1 and Y2 ?
    John S -
  2. Manual autochanger problems.
    Last Post: 05-02-2015, 01:14 AM
  3. WANTED: Centec 2A manual
    By Web Goblin in forum Items Wanted
    Last Post: 03-09-2012, 09:56 AM
  4. Translating the manual
    By Robin Hewitt in forum Moulding Machines
    Last Post: 01-09-2012, 01:21 PM
  5. Bridgeport Conversion
