05-09-2016 #11
Anyone have any views on what sort of speed and acceleration i should be aiming for?
Bearing in mind it has a relatively low spindle speed, even in aluminium, the feed rates are pretty low, I don't think it's worth going much above 2500mm/min?
I have read that there is a point in acceleration where Mach starts rounding corners etc, is this a known point or just something that can happen at some setting value?
Its currently set for 1000mm/min but that seems quite harsh when you do a rapid, it makes the machine shake a little at start/stop of the move.
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
