13-09-2016 #221
13-09-2016 #222
Dave, once setup drop a couple of shallow keyways in the plate both vertically and horizontally so you can drop a piece of key steel in to act as back and / or side stops to get parts square
John S -
The Following 3 Users Say Thank You to John S For This Useful Post:
19-09-2016 #223
25-09-2016 #224
26-09-2016 #225
26-09-2016 #226
Takes standard Fanuc G-code.
Plugs and sockets on the back to go direct to drivers, tool changer, VFD for spindle, encoder for threading or rigid tapping, probe and pendant.John S -
27-09-2016 #227
I would not say old style controllers, I would say professional. There is an element of setup but not as much as you would think. You will also need to change your habits if you are used to Mach or EMC, for example: just zeroing your part may not actually write the current offest to G54.
Some standalones, like my GSK980MDc also allow you access to the ladder logic so you can tweak it to your hearts content. Been trying to learn this myself but it is proving a tad difficult since there is very little to go on except some cryptic manuals.
Another element I have seen is that some controllers will accept DXF file direct input for drilled holes. You set each hole size in a different coloured layer and do all the coding on the console.
What I really like is that it moves away from the classic argument of EMC vs Mach, parallel vs motion controller etc. It just sort of works.https://emvioeng.com
02-10-2016 #228
To get back on track....
Have decided to replace the little Bridgeport motor and simple V/Hz VFD with a 3Hp inverter rated motor, sensorless-vector vfd, timing belt drive and encoder - this should give me usable torque and power from about 300rpm to 3000rpm and also semi-closed-loop speed regulation as Mach and the CSMIO controller will maintain the speed as load changes, up to the point of tripping the vfd :)
It means i can finally get rid of the clattering vari-speed pulleys and power-sapping drive and not have to mess with setting the speed manually. I also get actual speed display on-screen.
Also got the braking resistor so stopping time should be about 1s or less.Last edited by Davek0974; 02-10-2016 at 08:20 AM.
02-10-2016 #229
Told you ages ago you should have bought that step speed head with brand new 3Hp motor already fitted ( sigh )
John S -
02-10-2016 #230
Yeah i know, live and learn :)
I think this this will be a step ahead of even the step-pulley though as it will be timing belt drive and no step-pulleys at all ;)
Needs the timing belt as i'm mounting the encoder on the motor shaft at 1:1 drive
There are currently 12 users browsing this thread. (0 members and 12 guests)
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
