26-10-2016 #11
Which purpose?
If you mean the auxiliary spindle - this is only mounted when i need it, that was the whole idea really - its a normal Bridgeport plus a high-speed engraving/milling machine when needed.
The back of the ram was looked at, but adding a full Z-axis of any rigidity would be a considerable task, the aux idea is less cost and means not swivelling the ram.
I have even seen a full linear rail Z axis mounted between the ram and the existing mill head - the user locked the quill up all the time and moved the whole head up and down. Sounds nice but to get it working would not be cheap or easy i feel.
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
Manual autochanger problems.
By Saracen in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 05-02-2015, 01:14 AM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM -
Bridgeport Conversion
By Tony Goodwin in forum Bridgeport Milling MachinesReplies: 0Last Post: 08-08-2011, 08:11 AM
