Ive searched for this information but I'm missing something i want to setup in the Port and pin menu to trigger rely for plasma torch.thank for any help
Sent from my SM-G361F using Tapatalk
11-05-2016 #2
It's not hard just setup the Output Number with the pin numbers your using on your Bob. Then in spindle setup for CW select the output # you used for M3.
Now when you push Torch on it will be like calling M3 which turns on output#.
11-05-2016 #3
Still can figure it out can you give me a bit more detail sorry
11-05-2016 #4
Has your BOB got a relay on it?
11-05-2016 #5
11-05-2016 #6
No rely but has one fitted separately.
11-05-2016 #7
Hmm, the signal in to the relay is a green wire but all the BOB wires are white?
Somewhere, that relay should connect to one of the output pins on the BOB, lets call it PinX, in Ports & Pins you need to set output for spindle to X then in spindle settings set M03 CW & CCW to X as well.
I think that should do it.
12-05-2016 #8
In the ports and pins
Is it motor outputs or output signal ?
In output signals is it digit trig?
It also says spidle in motor out puts?
12-05-2016 #9
On my setup It's Output #1 and in spindle setup just put 1 in the CW and CCW boxes.
My BOB is configured for output 1 to fire the relay.
12-05-2016 #10
Got it to work thanks .the only thing is it will power the relay at the start of a program and only stop powering it at the end of doesn't stop for cut changes and holes etc
eBay: new xtreme value plasma cnc machine complete setup £4260
By rrossetti in forum Items On eBay UKReplies: 0Last Post: 22-02-2016, 10:14 PM -
FOR SALE: 3 sets of 4 xl pulleys and a plasma machine torch
By nobby in forum Items For SaleReplies: 0Last Post: 20-05-2014, 07:33 PM -
Plasma, Mach3, Sheetcam and a Proma Torch height controller..
By Davek0974 in forum Plasma Table MachinesReplies: 2Last Post: 14-04-2014, 03:49 PM -
controlling a stepper with a simple trigger switch
By phill05 in forum Stepper & Servo MotorsReplies: 13Last Post: 06-02-2014, 02:18 PM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM
