    http://www.ebay.co.uk/itm/2623588773...%3AMEBIDX%3AIT
    any good?
    I just bought one...........
    You'll have to let us know
    Why would you do that when you have the Pokeys57CNC for the same money? Made in Europe. I am trying it just now and for the moment works ok. Still had not the time to use all its functions.
    What i see here is the typical Chinese board- no name, version or whatsoever. No help file of software.Click image for larger version.
    where do you buy the pokeys 57? is it ethernet
    It is USB and/or Ethernet. Depends how you choose to connect it. https://www.poscope.com/PoKeys57CNC
    Totally agree, when you buy a motion controller, you really need to consider the support that you get, and if you buy from China from a no name exporter with no knowledge of the product, you are pissing in the wind if you think you will get any kind of support.
    Why would you buy then ask.!!! . . . Makes no sense.
    Wow, i missed that. Thought he was asking for advice.
    Out of interest I decided to try one as found a £30 version, I wanted to use a tablet with full usb output and a powered hub to run a machine rather than using desktops. I can tell you that it did not work as claimed, it came with pirated software well documented in Mach3 forums hall of shame, and a plugin that corrupted a system. Needless to say it was returned for a full refund make sure if your buying this stuff you buy from fleebay and pay with paypal to enable easy return. Fact that they are packaging pirate/counterfeit software is enough to have fleebay force a refund and have the vendor pay for product return but you need to have paid with paypal to ensure your rights.
    Quote Originally Posted by lucan07 View Post
    Are you sure we are talking about the same product? The one in the OP is priced around £100 all over on eBay. The ~£30 versions I have seen are NOT the same at all. Could you please post a link?
    BTW, if a USB version is what you want, why not getting a UC100 or UC300? OK, those cost more than £30 but they work well and is really supported by Mach3.
  1. smoothstepper with ethernet connection
    By terry1956 in forum Motor Drivers & Controllers
    Last Post: 22-02-2016, 03:22 PM
  2. Help mach3 ethernet set up
    By kell in forum Artsoft Mach (3 & 4)
    Last Post: 06-12-2015, 10:26 PM
  3. 200khz USB bob upgrading to 4th axis
    By dudz in forum Motor Drivers & Controllers
    Last Post: 05-04-2015, 11:06 PM
  4. USB/Ethernet controller for Mach3/4 advice
    By paulus.v in forum Control Hardware & Systems
    Last Post: 17-02-2015, 09:37 PM
  5. Replies: 0
    Last Post: 03-01-2015, 03:40 PM
