Thread: Eding cnc
Threaded View
17-05-2016 #1
Hi guys, ive been looking for the correct post processor to use in vcarve , but sadly ive not been able to source it. I decided to write one. Below is the post processor, as this is the first time ive ever done this, could you please glance your eye over it to see if I made any errors.. I'm not sure ive correctly done the manual tool change part..
Kind regards Bee...
+ Eding CNC - Vectric machine output configuration file
+ History
+ Who When What
+ Ben 16/05/2016 Created
POST_NAME = "Eding cnc (mm) (*.nc)"
FILE_EXTENSION = "nc"
UNITS = "MM"
SUBSTITUTE = "({)}"
+ Line terminating characters
LINE_ENDING = "[13][10]"
+ Block numbering
LINE_NUMBER_START = 0
LINE_NUMBER_INCREMENT = 10
LINE_NUMBER_MAXIMUM = 999999
+ Formating for variables
VAR LINE_NUMBER = [N|A|N|1.0]
VAR SPINDLE_SPEED = [S|A|S|1.0]
VAR FEED_RATE = [F|C|F|1.1]
VAR X_POSITION = [X|C|X|1.3]
VAR Y_POSITION = [Y|C|Y|1.3]
VAR Z_POSITION = [Z|C|Z|1.3]
VAR ARC_CENTRE_I_INC_POSITION = [I|A|I|1.3]
VAR ARC_CENTRE_J_INC_POSITION = [J|A|J|1.3]
VAR X_HOME_POSITION = [XH|A|X|1.3]
VAR Y_HOME_POSITION = [YH|A|Y|1.3]
VAR Z_HOME_POSITION = [ZH|A|Z|1.3]
VAR SAFE_Z_HEIGHT = [SAFEZ|A|Z|1.3]
+ Block definitions for toolpath output
+ Commands output at the start of the file
begin HEADER
"( [TP_FILENAME] )"
"( File created: [DATE] - [TIME])"
"( Eding CNC Postprocessor )"
"( Material Size)"
"( X= [XLENGTH], Y= [YLENGTH], Z= [ZLENGTH])"
"([FILE_NOTES])"
"(Toolpaths used in this file:)"
"([TOOLPATHS_OUTPUT])"
"(Tools used in this file: )"
"([TOOLS_USED])"
"[N]G00G21G17G90G40G49"
"[N]G80"
"[N] ([TOOLNAME])"
"[N]G00G43[ZH]H[T]"
"[N][S]M03"
"[N](Toolpath:- [TOOLPATH_NAME])"
"[N]([TOOLPATH_NOTES])"
"[N]G94"
"[N][XH][YH][F]"
+ Commands output at Manual tool change
begin TOOLCHANGE
"G28"
"[N]T[T]M6"
"[S]M03"
"( [TP_FILENAME] )"
"( Material Size)"
"([FILE_NOTES])"
"([TOOLS_USED])"
"[N]G80"
"[N] ([TOOLNAME])"
"[N]G00G43[ZH]H[T]"
"[N][S]M03"
"[N]G94"
"[N][XH][YH][F]"
+ Commands output for rapid moves
begin RAPID_MOVE
"[N]G00[X][Y][Z]"
+ Commands output for the first feed rate move
begin FIRST_FEED_MOVE
"[N]G1[X][Y][Z][F]"
+ Commands output for feed rate moves
begin FEED_MOVE
"[N]G1[X][Y][Z]"
+ Commands output for the first clockwise arc move
begin FIRST_CW_ARC_MOVE
"[N]G2[X][Y][I][J][F]"
+ Commands output for clockwise arc move
begin CW_ARC_MOVE
"[N]G2[X][Y][I][J]"
+ Commands output for the first counterclockwise arc move
begin FIRST_CCW_ARC_MOVE
"[N]G3[X][Y][I][J][F]"
+ Commands output for counterclockwise arc move
begin CCW_ARC_MOVE
"[N]G3[X][Y][I][J]"
+ Commands output for a new segment - toolpath
+ with same toolnumber but maybe different feedrates
begin NEW_SEGMENT
"[N][S]M03"
"([TOOLPATH_NAME])"
"([TOOLPATH_NOTES])"
+ Commands output at the end of the file
begin FOOTER
"[N]G00[ZH]"
"[N]G00[XH][YH]"
"[N]M09"
"[N]M30"
Setting ADTECH servos with Eding CNC software steps/AppUnit
By D-man in forum Stepper & Servo MotorsReplies: 55Last Post: 24-04-2016, 02:50 PM -
CONVERSION: Sieg X2 super with ball screws and Eding CNC controle
By Soren DK in forum Conversion Build LogsReplies: 2Last Post: 11-04-2016, 08:40 PM -
Eding CPU5A4E controller and Siemens G110 VFD.
By calgone in forum EdingCNC (CPU5, CPU5A)Replies: 4Last Post: 06-02-2015, 11:31 PM
