Page 2 of 2 FirstFirst 12
    A problem...
    On the top of the fine-feed screw at the side, there is a screw behind which i think should be a spring and a little bone-shaped object - this bone has broken and the end is jamming the screw in the head which needs to come out. Its well and truly jammed in there.
    Any suggestions here?
    A problem...
    That is actually very common on Bridgeports. On my KRV it was hollow. I removed it be jamming a pin in but you need to wiggle the depth stop screw a bit to release it.
    Another option would be to magnetise a paperclip?
    https://emvioeng.com
    Yeah tried magnets, that thing is jammed in there good not just sitting there. It never did work properly - this maybe why.
    Will have to get tougher on it i think, one way or another its coming out though.
    Got it!
    Another two hours messing, a Dremel, two small screwdrivers, compressed air and WD40 and it's out.
    Now i can continue on the rest of the job.
  5. #15
    I need to pull this gear to get the crud out from behind - any suggestions??
  1. HSM Advisor - High Speed Machining feed & speed calculator
    By magicniner in forum CAD & CAM Software
    Last Post: 20-01-2014, 12:57 PM
  2. NEW MEMBER: In over my head
    By Tele45 in forum New Member Introductions
    Last Post: 03-01-2014, 02:30 PM
  3. FOR SALE: End mills and Ball mills for sale......
    Last Post: 16-02-2011, 12:37 AM
  4. WANTED: Looking for used mills ?
    By Meldreth_Nick in forum Items Wanted
    Last Post: 20-09-2010, 01:31 PM
  5. axminster mills
    By richb77 in forum Milling Machines, Builds & Conversions
    Last Post: 22-10-2008, 05:02 PM
