28-05-2016 #21
Although the single X ballscrew, gantry side plates and overhanging Y axis (due to ballscrew position ) will reduce stiffness and performance my experiences of this type of design is that it is no problem for wood and plastic and will cut them all day long. If that is the intended use the I see no great issues on the mechanical side
Occasional aluminium plate is ok but for serious aluminium work this is not the machine to use and you need something stiffer in design including profile rails on most/all axes
Aluminum finish
By Boyan Silyavski in forum Metal Finishing TechniquesReplies: 3Last Post: 07-09-2014, 07:32 PM -
Aluminum router build - Could use some input
By Tumblebeer in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 01-09-2014, 09:48 PM -
NEW MEMBER: where to buy aluminum extrusion
By troyboy1 in forum New Member IntroductionsReplies: 3Last Post: 21-07-2014, 01:52 PM -
tool for aluminum on uk
By edgas10 in forum Tool & Tooling TechnologyReplies: 1Last Post: 26-04-2011, 11:23 AM
