    Hi Slixxor,
    I am in Melb Aus. If I can assist you in any way.
    You might not of seen this thread http://www.mycncuk.com/threads/4356-...upported-rails
    The square tube will rhomboid with side load ( assuming gantry uprights are the top of the frame )
    Three trucks are better than two trucks ( better load spread )
    Regarding tool load what spindle are you using ..kW RPM etc ,, have you seen "CNC Cookbook"
    Finally, Hey Ger, Very nice to see you here.
    Paul
    Hi Paul. Yes I have seen the page. I am planning on using a 2.2kw water cooled spindle. Z axis range of 300mm. My rails for Z are 450mm long. I am adding 45° gusset/supports to both sides of each corner of the frame. I will be running dual ball screws on the X axis to minimize racking each with their own nema34 34HS59-5004S. Still havent decided if I'll be using the same size stepper on Z just yet or slightly smaller.
    I haven't done a cad example of my design for reference. May do shortly pending work commitments.
    Lives in Plymouth, United Kingdom. Last Activity: 2 Weeks Ago Has a total post count of 1,749. Received thanks 299 times, giving thanks to others 11 times.
    Sure that those Nema 34s are a good fit for this size machine? Nema 23 would be more usual and this is a situation where over-building is definitely a bad thing. I was talking to someone last night who bought someone else's project router and with Nema 34 ("bigger must be better") he was getting no more than 1m/min when with the correct motors he should have been seeing 5m/min or more. Big motors come with much more inertia and high inductance which are both speed killers. Might be worth a bit of investigation?
    The bed size is 1300x1000. I am happy to run whatever I need in order to be able to mill aluminium comfortably. I opted for the 34's due their torque at low rpm. Can anyone suggest a nema23 suitable for the application, they certainly are cheaper :)
    Quote Originally Posted by Slixxor View Post
    nema 34 is overkill and won't work as expected try these https://www.cnc4you.co.uk/Stepper-Mo...YGH301B-Nema23 more than capable for that size of machine
    Thanks Clive S,
    you've saved me $420 AU. Does anyone else agree with Nema23 23HS45-3504S being the best choice for a steel gantry and Z axis?
    that will likely weigh over 30kg?
    I'm using these in a slightly larger machine, steel gantry probably weighs around 50kg, and I'm not expecting any problems. It's a very common setup. You do need to drive them with a suitable voltage - 60V or more.
    Agree with 23's .. ball screws = 10 mm is ok (5mm better axial load deflection needs looking at )
    I assume you are in Aust, so these links might be of assistance. Both are in Melb.
    http://www.homanndesigns.com/
    http://stores.ebay.com.au/CNC-AND-CU...=p4634.c0.m322
    CHECK THE SCREW LENGTH This guy normally lists travel length ..
    Paul
    My 1000x700 build uses Mema 23 425oz 3amp at around £20 each, and they plenty of torque and speed, forgot to change DOC other day set to 3mm 6mm 2 flute for MDF (cuts MDF 6mm 2 flute at 15mm DOC Regularly), so ended up slot cutting 5083 aluminium at 3mm DOC 6mm 2 flute 1000mmpm FR, stepper torque was not a problem and it cut without incident but was working harder than it would normally.
  1. WANTED: 2 x 20mm Fully Supported Round Rail
    By longy in forum Items Wanted
    Last Post: 30-03-2014, 09:21 PM
  2. Replies: 0
    Last Post: 04-12-2011, 03:23 PM
  3. Anybody used these linear bearings before?
    By pjl83 in forum Rails, Guideways & Bearings
    Last Post: 08-06-2010, 12:42 PM
  4. Supported linear rail question.
    By IN-WondeR in forum Rails, Guideways & Bearings
    Last Post: 05-02-2010, 12:25 PM
  5. 16mm supported rail how many linear bearings
    By progomez in forum Rails, Guideways & Bearings
    Last Post: 15-01-2009, 09:39 PM
