Thanks Clive, I dont have an issue with switchmode PSU's. As a worst case i'll make a quick back EMF circuit and put some filtering caps across the bridge.
You are dead right about the affect of inductance on supply voltage, especially at higher RPMs. So I have found a reasonably priced torquey Nema23 model
http://www.ebay.com.au/itm/3PCS-3Nm-...EAAOSw37tV85jU
inductance is 3.8mH - The lowest i've seen on ebay in that size.
What is everyones thought on this motor?
27-05-2016 #2
Not quite sure whether you mean you'll use a switch-mode supply or not. However, the linear supply is often better to drive steppers; the duty cycle of the load is relatively low, even though the peak demand can be high. With a SMPS, you need to rate it for max peak load to avoid it going into current-limiting where a linear supply can handle the peaks even if rated for average load. But then, you can buy cheap SMPS from China...
WANTED: 2 x 20mm Fully Supported Round Rail
By longy in forum Items WantedReplies: 0Last Post: 30-03-2014, 09:21 PM -
FOR SALE: ballscrews, supported linear rails, linear bearings, complete kit. for sale
By cutter in forum Items For SaleReplies: 0Last Post: 04-12-2011, 03:23 PM -
Anybody used these linear bearings before?
By pjl83 in forum Rails, Guideways & BearingsReplies: 9Last Post: 08-06-2010, 12:42 PM -
Supported linear rail question.
By IN-WondeR in forum Rails, Guideways & BearingsReplies: 20Last Post: 05-02-2010, 12:25 PM -
16mm supported rail how many linear bearings
By progomez in forum Rails, Guideways & BearingsReplies: 13Last Post: 15-01-2009, 09:39 PM
