17-07-2009 #1
I need to mount a 13mm drill chuck onto a stepper motor shaft (don't ask!)
It seems most 13mm drill chucks come with a 1/2" female thread. Therefore I need a stepper motor shaft (M8) to 'drill chuck' thread widget/adapter ....obviously no such beast exists.
Now then, I could lay out for a 1/2" 24tpi UNF die ...but this is a one off that I'll never use again...so that not very cost effective. Therefore I was wondering ...would it be do-able to just re-tap the drill chuck's existing female 1/2" 24tpi UNF thread...to be an M12? (because I already have metric taps/dies)
Or will this be problematic?! (one issue jumps out, is that 12mm is slightly smaller than 1/2")
(btw the end result - if I get there - will be under light load)
17-07-2009 #2
Why not buy (or borrow) a 1/2" UNF bolt, cut the head off then drill it out to suit your stepper then put in a couple of grub screws in to hold it place.
JD!
17-07-2009 #3
Thinking about it, leave the head on then you can screw the chuck up to it and also put the grub screws through the flats on the head.
17-07-2009 #4
17-07-2009 #5
Are you sure it's 1/2" x 24 ?
Most chucks I have seen are 1/2" x 20 UNF
BTW Steve if you 'borrow' a bolt what happens when the guy wants it back and you have gronched it up ? :question::question:
.John S -
17-07-2009 #6
I was basing the "borrow" coment on what people say to me when they want to "borrow" something, nine times out of ten I never see it again....!
17-07-2009 #7
It's great to nestle in the bosom of those that know.
I went and checked what I'd bought, transpires I bought a 10mm chuck (not a 13mm chuck)
http://cgi.ebay.co.uk/ws/eBayISAPI.d...lenotsupported
"3/8" x 24 thread."
Fortunately, the bolts I have were specifically bought for it at the time (a failed idea that I had, that I can now re-use these bolts for)
"Hacking" and "Modding"
CNC machine "Spanish" model . Advice and opinions needed!
By shapebusters in forum Machine DiscussionReplies: 17Last Post: 12-03-2014, 06:21 AM -
Interesting Article "Makers unite - the revolution will be home-made"
By Fivetide in forum General DiscussionReplies: 4Last Post: 28-09-2012, 12:06 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM -
My apologies to "Andy" for the delay ... internet connection problem
By ali hedi in forum General DiscussionReplies: 1Last Post: 25-12-2010, 06:05 PM
