24-05-2016 #15
Worth checking that "steps per" settings are correct in Mach3? Or do gcode files from other CAM packages work ok?
Increasing the capacity of a Rabit 2/3 injection molding machine?
By JRR in forum Moulding MachinesReplies: 14Last Post: 11-05-2016, 09:15 PM -
No detail imported stl file
By luke11cnc in forum Rhino 3DReplies: 4Last Post: 30-01-2015, 10:19 PM -
RFQ: 5mm steel plate plasma or laser - can supply sheetcam g-code for mach 3,
By nobby in forum Projects, Jobs & RequestsReplies: 0Last Post: 07-03-2014, 07:56 PM -
Imported L298 Arduino Modules
By boldford in forum Motor Drivers & ControllersReplies: 4Last Post: 30-07-2012, 11:06 PM -
Increasing timing pulley bore size from 3mm t0 3.175mm
By divdav in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 14-05-2011, 09:45 AM
