25-05-2016 #2First welcome to the forum. Ok you won't go far wrong with these :https://www.cnc4you.co.uk/Stepper-Mo...YGH301B-Nema23 or http://www.zappautomation.co.uk/elec...per-motor.htmlNema23 motors are widely and fairly cheaply available on ebay, but which ones ? And how good/bad would they be ?
It all depends if you want to reuse the parts you are buying when you decide to build a stronger machine if so buy wisely as rubbish drives and motors will disappoint. Also keep away from any kits you see as they are never matched.
look for drives like AM882 leadshine.
Read through some of the build logs on here to get inspiration Then put a design up and ask questions. Good luck with the build..Clive
Advice needed on everything
By chrisjames in forum General DiscussionReplies: 12Last Post: 11-11-2015, 11:40 PM -
Build log. Design advice needed.
By eurikain in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 25-06-2015, 06:53 PM -
BUILD LOG: my router build - advice needed
By thomashomer1986 in forum DIY Router Build LogsReplies: 10Last Post: 02-12-2013, 11:45 PM -
BUILD LOG: New cnc router build looming, advice needed
By Mad Professor in forum DIY Router Build LogsReplies: 5Last Post: 06-11-2012, 08:12 PM -
new mashine build advice needed
By Finrod in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 14-10-2008, 11:05 PM
