    Hi all I 've rewired a plasma table I now have a problem now the z motor is rumbling now when it supost to be moving (not when at a stop)it seems to be fighting to move but won't move at all.
    Sent from my SM-G361F using Tapatalk
    See where you got the name, sounds to me as if motor is wired incorrectly double check your wiring or post some pics of motor and driver with motor and driver details.
    Your funny. The wires match the pins and ports wires for step and direction
    you need to give more information, without more information, it is unlikely anyone will know how to help you.
    What about the wires between driver and stepper? Is each phase wired up correctly? It can damage the driver if incorrect or direct short. Are they series or parallel ?
    Quote Originally Posted by whensparksfly View Post
    This must have been done for a reason and will have included some changes, otherwise there was no reason to do it.
    Providing these details will help, otherwise you'll have to wait until the forum crystal ball comes back from repair ;-)
    - Nick
    Got sorted the wire was broken
    Ye that's what the Crystal ball would have said.!!!
    As I said check the wiring, no point in going to the right pins without creating a circuit. I'm funny!
  1. Help setting up Ethernet Smooth Steper
    Last Post: 19-10-2015, 06:01 PM
  2. Replies: 2
  3. Threaded bar, steper motor and a plasma cutter.. your thoughts?
    By gr8fun in forum Gantry/Router Machines & Building
    Last Post: 27-11-2012, 05:14 PM
  4. servo motor as spindle motor
    By Scott in forum General Discussion
    Last Post: 03-10-2010, 06:42 PM
