    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    As a first step, I'd be tracing the wires to see where they go inside the control box.
    I'd guess only 4 of the wires are for the stepper, with the others being inputs for sensors/switches, and/or outputs for controlling locks/actuators.
    Hopefully by tracing where the wires go, you'll be able to work out what they do.
    I'd guess only 4 of the wires are for the stepper.
    Steppers come in 4, 6 and 8 wire flavours, not just 4, it is possible to connect a 4-wire driver to 6 and 8 wire steppers by externally connecting the circuits to a 4-wire configuration, but if you have a 6 or 8 wire driver you cannot use a 4 wire stepper
    Which is why I said to physically trace the wires inside the control box. The stepper driver wires should all connect in the same area, possibly to an individual driver, which means you know exactly what wires power the stepper motor.
    Then it just leaves the other individual wires, which by tracing, will hopefully connect to a terminal with some form of name to work out what they do.
    I would very much doubt that all 8 wires are solely for powering a stepper motor, given Boxford typically only use 4 wire drivers.
  4. The Following User Says Thank You to m_c For This Useful Post:
  5. #4
    That is really useful information.
  6. #5
    [QUOTE=m_c;80406]Which is why I said to physically trace the wires inside the control box. The stepper driver wires should all connect in the same area, possibly to an individual driver, which means you know exactly what wires power the stepper motor.
    I would very much doubt that all 8 wires are solely for powering a stepper motor, given Boxford typically only use 4 wire drivers.[/QUOTE
    Sound advice, been into it today, 8 wires in the socket
    2 red singles 2 orange singles.
    1 multicore red blue green yellow.
    traced back to 2 boardsClick image for larger version.
ID:	18516Click image for larger version.
    Ok up til there . . . . I can meter out one of the other steppers to work out the wiring, but I haven't a clue what the red and orange ones do - they are a bigger section (18swg) than the multicores. Could they be for power ? Galloping ahead, I have never seen one of the Boxford 4th axis' in the flesh, does anyone know if they are direct drive or reduction ?
  7. #6
    [QUOTE=Warden5;80437]
    just seen a Boxford 4th axis underneath view - right angle drive with proxi switch, all wires black except earth, hmmm
  8. #7
    All black with an earth sounds like CY cable and the blacks are usually numbered if you can get a better look.
  9. #8
    By the looks of it, the red and orange pairs are the stepper motor wires. Even without the fact the board has 4th Axis Drive written on it, the pair of chips mounted to the heatsink are very much like an old stepper motor drive.
    I'd also guess red are one pair, and orange the other pair.
    As for the multicore wiring, I'd power things up, and see what kind of voltages you get on the wires, as that'll give us an idea of what they might potentially be.
  10. #9
    Yep, looks like cy.to me.
    unfortunately it's on a photograph that I can't do anything with !
  1. eBay: boxford 125-160 TCL chuck with spindle axis
    By sbdtasos in forum Items On eBay UK
    Last Post: 20-10-2015, 11:07 PM
  2. Replies: 22
    Last Post: 29-05-2015, 11:30 AM
  3. Boxford VMC 260 Z axis removal? Any ideas?
    By Roboteernat in forum Boxford Vertical Mills
    Last Post: 19-03-2015, 07:10 PM
  4. Problem with Mach 3 converted lathe x axis Boxford TCL 160
    By FarrerDesign in forum Boxford Lathes
    Last Post: 07-08-2013, 09:37 PM
  5. Boxford VMC190 Retrofit Problems, axis sounds very rough
    By mikegolding in forum Boxford Vertical Mills
    Last Post: 09-06-2013, 09:11 PM
