Thread: Closed Loop steppers
Ok thts great, mechanically this thing is sweet, just I have no idea what I need to buy to get it to running on the electrics side.
17-07-2009 #2
This is the machine, I would like to get this running as a 3D router, any ideas on bits that are needed? Any help would be appreciated.
17-07-2009 #3
17-07-2009 #4
yeh I thought it was a good buy....when I picked it up today the guy said he paid £24 at auction for it, insolvency deal....thanks a lot I thought, didnt really need to know that!
x axis - VEXTA ASM66AK-T7.2 CLOSED LOOP STEP MOTOR
Y axis - VEXTA ASM66AK-T7.2 CLOSED LOOP STEP MOTOR
z axis - VEXTA PK266-02B 2 PHASE STEPPER MOTOR WITH CLEAN DAMPER
There are quite a few optical limit switches all over it.
17-07-2009 #5
OK, I've added links to the data sheets to the parts above.
The closed loop (X, Y) motors are going to be a little tricky. They are geared 7.2:1. According to the operating manual the standard driver for these does 0.05deg/pulse, i.e. 7200 pulses/rev, which means the motor does 1000 steps/rev, some form of microstepping drive. This is great for a very accurate pick n place mechanism but far too slow for a router. You may have to look at replacing these motors, but note they are offset (motor body to shaft) due to the gearbox. Might need a new bracket making up.
The Z motor is a fairly conventional 2-phase bipolar or unipolar motor. 1.4A phase (bipolr series)
17-07-2009 #6
Thanks, so what I need is a new pair of motors and a 3 axis driver kit to make this work properly?
Will flog the Vexta's off on ebay I think then. What size motor roughly do you think I will need for this machine?
No worries on making bits I have a 3,000 sq ft workshop filled with machines, so I am all good.
18-07-2009 #7
Measure up the lead on the X & Y axis and then we can determine the motor speed and torque required for an appropriate traverse rate. Suspect 3Nm motors will do the job as the existing motors are 2.5Nm at 250revs/min in a 60mm case. A newer motor will do the same in a 34mm case so there is room to move. The existing have a flatted 8mm output shaft, but the smaller motors may have a 6 or 6,35mm shaft so some work on the couplings may be needed. Its probably not possible to use the current X&Y motors as they are not spec'd independently of the matching controller.
Controller for 8NM closed loop leadshine drivers
By Matt81 in forum Motor Drivers & ControllersReplies: 5Last Post: 19-06-2014, 09:08 AM -
FOR SALE: SuperPID v2 (Closed-loop PID Router Speed Controller)
By Mad Professor in forum Items For SaleReplies: 18Last Post: 23-04-2013, 10:48 AM -
Testing Leadshine closed loop stepper system.
By JAZZCNC in forum Stepper & Servo MotorsReplies: 10Last Post: 13-10-2012, 05:39 PM -
Closed Loop Stepper Compared with Open Loop Stepper
By Leadshine-Erci in forum Stepper & Servo MotorsReplies: 0Last Post: 25-05-2012, 08:11 AM -
Droping Steps, closed loop ? HELP !!!
By bobin in forum Machine DiscussionReplies: 7Last Post: 20-05-2009, 03:56 PM
