    Just Looking through a box of old motors I have here at work,
    There are three with the following detail
    1.8 degree step, Holding Torque 550mNm
    2 VDC 2.8A
    Are these any good? Noticed that you put down a torque of 3Nm so what is mNm?
  2. 3nm is 300mnm just like 300mnm is 30 ncm.
    5.5Nm is a reasonable amount of holding torque and if you use the existing belt they should give you enough torque to run the machine, but you need to define what you are using it for to determine how much power you need.
    Quote Originally Posted by funkmonkey View Post
    2 VDC 2.8A
    I want to build a router out of it, mostly for machining wood, but would like the ability to do the odd ally job too.
    why, what wrong with it?
    Maybe so but it’s a lot better than some of the tat I have seen floating around, thats for sure. I don’t need a massively robust machine, I own an aerospace tool room with many CNC machines, I just need this machine to help my dad who sits at a desk making 100's of wooden miniatures by hand, as his part time business. Just wanted to help him out a bit.
  6. You wont be able to accurately do anything with ali, it will flex way too much.
    reducing the height will help with the ridgidity.
    I think that you could use it for routing wood and plastics but that is about it, but don’t expect too much.
    You may also have a bit of hysteresis due to the belts if you try and move to quick.
    cos its what I wanted to do.........
  8. Quote Originally Posted by Kip View Post
    Any chance of a list of parts you've made for the aerospace industry(mostly the models they are on)
    Forewarned is forearmed as the saying goes....
    Kip, I know that is said in jest, but its getting personal. You may not agree with funkmonkey's purchase or the viability of what he wants to do, but thats no reason to cast aspersions...
    Irving (with my moderator hat on)
  1. Controller for 8NM closed loop leadshine drivers
    By Matt81 in forum Motor Drivers & Controllers
    Last Post: 19-06-2014, 09:08 AM
  2. FOR SALE: SuperPID v2 (Closed-loop PID Router Speed Controller)
    By Mad Professor in forum Items For Sale
    Last Post: 23-04-2013, 10:48 AM
  3. Testing Leadshine closed loop stepper system.
    By JAZZCNC in forum Stepper & Servo Motors
    Last Post: 13-10-2012, 05:39 PM
  4. Closed Loop Stepper Compared with Open Loop Stepper
    By Leadshine-Erci in forum Stepper & Servo Motors
    Last Post: 25-05-2012, 08:11 AM
  5. Droping Steps, closed loop ? HELP !!!
    By bobin in forum Machine Discussion
    Last Post: 20-05-2009, 03:56 PM
