Thread: Z axis moves below set zero
When I toggle the z with the arrow keys it moves In inchs and the z and y move in mm
Sent from my SM-G361F using Tapatalk
30-05-2016 #2
30-05-2016 #3
If Z is moving around 25 times further than required then the motor tuning for the Z axis is probably incorrect, it is most likely doing exactly what it has been told to do.
Make sure tuning is correct may be totally different to X & Y and be sure to save axis settings every time changes are made, you solved the motor tuning problem with auto calibration in this or previous thread, how are you measuring that movement accurately with much smaller Z axis movement any errors may be larger.
30-05-2016 #4
What setting do you mean I'm new to this
30-05-2016 #5
The motor steps per unit in motor tuning.
30-05-2016 #6
I done the automatic motor configuration in the setting menu measured it movement it was correct.
When I toggle the z and y with the arow keys it will work in mm I can be seen that the movment matchs the fro but when z is moved the movement in the dro and a axis will move in inchs
30-05-2016 #7
The only way that can happen is if you've got your motor tuning wrong.
Motor tuning units are set for all axes at once so you can't have a mix.
If tuning units are set to mm and X and Y work fine you will get really close if you take the number for "steps per" currently set for Z and multiply it by 25.4, Mach3 can't tell when you instruct it to do stupid things, it simply does what it's told.
- NickLast edited by magicniner; 30-05-2016 at 10:13 AM.
30-05-2016 #8
When I stated in your previous thread to check wiring you responded I was definitely wrong then that you had found the broken wire.
When I stated the code was wrong and would not run in a different thread, you replied I was wrong and later PM'd me to get the edit to correct that code.
Again I try all axis are using same measurement scales they cannot do otherwise, therefore your tuning steps per unit are incorrect they are for mm's if axis is moving in mm and for Inches or out by a factor of 2540% if axis is moving in inches instead of mm.
There is no alternative computers just do what they are told, you put rubbish in you will only get rubbish out its the way it is.
30-05-2016 #9
30-05-2016 #10
Slaved axis, 2 steppers on Y axis with a PLC4x-G2 ? what about the XP23 connector ?
By pierantoine in forum General ElectronicsReplies: 9Last Post: 23-05-2015, 02:07 PM -
problem: y-axis only moves in one direction using TB6560 board off email
By polysoul in forum Machine DiscussionReplies: 9Last Post: 08-06-2012, 12:12 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
moves ok when using jog in mach3 but....
By deannos in forum General DiscussionReplies: 2Last Post: 28-12-2011, 09:40 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
