Thread: Z axis moves below set zero
If Z is moving around 25 times further than required then the motor tuning for the Z axis is probably incorrect, it is most likely doing exactly what it has been told to do.
Make sure tuning is correct may be totally different to X & Y and be sure to save axis settings every time changes are made, you solved the motor tuning problem with auto calibration in this or previous thread, how are you measuring that movement accurately with much smaller Z axis movement any errors may be larger.
Slaved axis, 2 steppers on Y axis with a PLC4x-G2 ? what about the XP23 connector ?
By pierantoine in forum General ElectronicsReplies: 9Last Post: 23-05-2015, 02:07 PM -
problem: y-axis only moves in one direction using TB6560 board off email
By polysoul in forum Machine DiscussionReplies: 9Last Post: 08-06-2012, 12:12 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
moves ok when using jog in mach3 but....
By deannos in forum General DiscussionReplies: 2Last Post: 28-12-2011, 09:40 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
