Thread: Z axis moves below set zero
30-05-2016 #21
The only way that can happen is if you've got your motor tuning wrong.
Motor tuning units are set for all axes at once so you can't have a mix.
If tuning units are set to mm and X and Y work fine you will get really close if you take the number for "steps per" currently set for Z and multiply it by 25.4, Mach3 can't tell when you instruct it to do stupid things, it simply does what it's told.
- NickLast edited by magicniner; 30-05-2016 at 10:13 AM.
Slaved axis, 2 steppers on Y axis with a PLC4x-G2 ? what about the XP23 connector ?
By pierantoine in forum General ElectronicsReplies: 9Last Post: 23-05-2015, 02:07 PM -
problem: y-axis only moves in one direction using TB6560 board off email
By polysoul in forum Machine DiscussionReplies: 9Last Post: 08-06-2012, 12:12 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
moves ok when using jog in mach3 but....
By deannos in forum General DiscussionReplies: 2Last Post: 28-12-2011, 09:40 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
