Thread: Z axis moves below set zero
30-05-2016 #32
Told you this before The steps per is not something that you tune or tweak. It's Calculated and Fixed number based off mechanical and Drive parameters.
Motor tuning and Steps per are completely different things. Motor tuning won't make the machine move wrong distance.! (well it will if over tuned but that would be missed steps and very small amounts)
Your replies are not helping us help you.!! . . Be more clear please. Comments like " zero all the axis press reg move up the z from the materal" don't help tell whats happening or not.
Slaved axis, 2 steppers on Y axis with a PLC4x-G2 ? what about the XP23 connector ?
By pierantoine in forum General ElectronicsReplies: 9Last Post: 23-05-2015, 02:07 PM -
problem: y-axis only moves in one direction using TB6560 board off email
By polysoul in forum Machine DiscussionReplies: 9Last Post: 08-06-2012, 12:12 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
moves ok when using jog in mach3 but....
By deannos in forum General DiscussionReplies: 2Last Post: 28-12-2011, 09:40 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
