    Not on my current MDF bed and on the mill usually in the vice when edge or centre finding vice is easy to isolate when mounting.
    Ah Ok.
    Most of my stuff is clamped to the mill table so no way of isolating it really, would need to be an isolated tip probe.
    This would be an isolated tip, pick up the wires from beeper or led switch to connect to mach probing and save 90%
    http://www.ebay.co.uk/itm/160mm-Led-...25.m3641.l6368
    Interesting, thanks, I would have to butcher it though as the body is 20mm - mini-mill max is 12mm
    Still, it might serve as a useful donor of parts.
    They do a 12mm as someone was posting the other week on here "Boyan" I think i recall, and as Mach inputs are usually 5v even taking battery connections should work, leaving beep and led intact.
    Chaz's Avatar
    I have two of these. I got mine from the USA but I think its the same unit. Does what I need, its wired as a probe input via my CS Labs into Mach. I dont have a plugin to use it properly yet, just a lack of time from my side. Not as accurate as a Renishaw but nowhere the same cost either.
    I have one spare - happy to sell it for around £75 including local shipping.
  7. The Following User Says Thank You to Chaz For This Useful Post:
  8. #7
    Lives in East Lothian, United Kingdom. Last Activity: 4 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    I've got the deepgroove1 touch probe, although I think it's one of the more expensive ones now, however I can't fault it.
    Repeatability is in the sub 0.05mm range, but some/most of that is likely to be lack of repeatability in the machine it's mounted on. I made up a small interface board for mine, as I didn't want to switch the KStep 24V opto directly with it, so the board means the probe is only switching 5V. The board also provides a couple LEDs so I know it's got power, and if the probe is triggered.
  1. Probe-it / any users ?
    By dudz in forum CAD & CAM Software
    Last Post: 02-11-2015, 11:51 PM
  2. RFQ: Cooler probe
    By DAHammond in forum Projects, Jobs & Requests
    Last Post: 10-06-2015, 05:18 PM
  3. Touch Probe Project
    By Washout in forum Tool & Tooling Technology
    Last Post: 20-11-2013, 12:59 PM
  4. Touch probe stylus - where to buy?
    By Mad Professor in forum Marketplace Discussion
    Last Post: 05-08-2013, 07:07 PM
  5. Touch Probe
    By luke11cnc in forum Probing, Digitizing & Scaning
    Last Post: 31-01-2012, 01:16 AM
