    Hi Pro
    I bought the 5 axis one that you see on flea bay and was quite surprised at the quality. Beware though you have to do your homework on the instructions. This one has isolated control, jog wheel connection and separate homing switch connections. i am running the astrosyns also it works fine with EMC2. A lot of board for the £51 i paid for it. It is also 2 amps total per motor which they don't mention (would not risk at 2.5 which is max for the chips). The fan could do with being upgraded. Also take note everything is powered off the same supply.
    Paul
    Heres the destruction they send you. Note this will also work up to 36v not 24 like it says.
    Attached Files Attached Files
  1. stepmotordriver.com professional stepper motor driver manufacturer from China
    By stepmotordriver.com in forum Manufacturer News
    Last Post: 01-03-2014, 09:07 AM
  2. 3 wire stepper motor drivers?
    Last Post: 17-08-2013, 10:01 PM
  3. Setting up stepper motor drivers
    By croy in forum Motor Drivers & Controllers
    Last Post: 30-09-2012, 09:51 PM
  4. Purelogic featured stepper motor drivers PLD86 and PLD545.
    By Purelogic R&D in forum Manufacturer News
    Last Post: 07-06-2012, 08:36 AM
  5. Total novice seeks advice on stepper motor drivers
    By R.Andersen in forum Motor Drivers & Controllers
    Last Post: 25-01-2012, 11:34 AM
