Thread: Total newbie.
02-06-2016 #2
The photograph is not very crisp but as far as I can see, the corners of the outer (frame) moulding are very sharp. This does not look as if it was cut as a single panel as you cannot machine sharp internal corners like this with a router. You can see this in cheap doors made from a single MDF panel - the internal corners are rounded. The frame was probably made from four components and the moulding machined before assembly. I would guess that you could probably match the moulding shape with a commercially-available router bit but it's a matter of ploughing through cutter catalogues to find a matching profile. More likely, the mouldings were cut on a spindle moulder which gives you access to many more moulding profiles, but we're moving away from the CNC area now!
NEW MEMBER: Total Newbie....looking for the light....
By MOCNC in forum New Member IntroductionsReplies: 2Last Post: 01-07-2014, 10:37 PM -
NEW MEMBER: Hello - total newbie!
By eggsBenedict in forum New Member IntroductionsReplies: 15Last Post: 05-01-2013, 12:47 AM -
NEW MEMBER: Total noob about to embark on a build.
By Wal in forum New Member IntroductionsReplies: 6Last Post: 21-12-2012, 02:48 AM -
NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
By DarkWalkJRB in forum New Member IntroductionsReplies: 2Last Post: 07-02-2012, 08:31 PM -
Total novice and lost
By sfallan in forum Machine DiscussionReplies: 48Last Post: 10-09-2010, 10:35 AM
