Thread: eBay Nema23 Stepper mounts
It's cheap for a reason. I would not buy those. I bought these and they work fine, but there are others which may be even better.
http://www.ebay.com/itm/CNdelivery-free-shipping-Stepping-motor-Aluminium-NEMA23-Motor-Mounts-bracket-/152108774934?hash=item236a63b616
05-06-2016 #2
I used those for the initial conversion of my mill because they suited the way I wanted to mount the motors, they worked well and were fairly robust but now my mill and router are running I have cut some better T shaped ones from aluminium, the aluminium design would have been no good for my machines design.
05-06-2016 #3
Thanks, I will just make my own out of 6mm steel angle as I was originally going to do.
05-06-2016 #4
05-06-2016 #5
I used them on a different machine, my Micro mill so just mounted them on 2020 extrusion which I skimmed just enough to get correct spacing.
http://www.mycncuk.com/attachment.ph...5&d=1456081931
The measurements on mine are 19.2mm to edge of hole which is 38.2mm diameter so from back of plate to centre of motor spindle should be around 38.3mm, side to hole is 13.3mm so edge to centre of hole is 32.4mm. Hope this helps.
05-06-2016 #6
eBay TB6560 Stepper Motor Driver Boards
By Mad Professor in forum Motor Drivers & ControllersReplies: 127Last Post: 22-08-2018, 05:32 PM -
RFQ: RFQ Nema23 stepper mount
By r0bsk1 in forum Projects, Jobs & RequestsReplies: 0Last Post: 15-02-2014, 02:16 PM -
By irving2008 in forum Motor Drivers & ControllersReplies: 13Last Post: 07-04-2010, 04:48 PM -
DIY Nema23 Motor Mounts
By Lee Roberts in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 23-08-2009, 06:08 PM -
eBay Stepper Motor Drivers from China
By Mad Professor in forum General ElectronicsReplies: 6Last Post: 20-07-2009, 10:54 PM
