    Quote Originally Posted by lucan07 View Post
    I used those for the initial conversion of my mill because they suited the way I wanted to mount the motors, they worked well and were fairly robust but now my mill and router are running I have cut some better T shaped ones from aluminium, the aluminium design would have been no good for my machines design.
    awesome news, saves me ginning around too much. I was planning on reinforcing it. and the price seems more than reasonable. I may be 4 and try them anywa. did you still need a spacer to elevate it to the eight of the ball screw bearing or was it flush?
    I used them on a different machine, my Micro mill so just mounted them on 2020 extrusion which I skimmed just enough to get correct spacing.
    http://www.mycncuk.com/attachment.ph...5&d=1456081931
    The measurements on mine are 19.2mm to edge of hole which is 38.2mm diameter so from back of plate to centre of motor spindle should be around 38.3mm, side to hole is 13.3mm so edge to centre of hole is 32.4mm. Hope this helps.
    legend.
  1. eBay TB6560 Stepper Motor Driver Boards
    By Mad Professor in forum Motor Drivers & Controllers
    Last Post: 22-08-2018, 05:32 PM
  2. RFQ: RFQ Nema23 stepper mount
    By r0bsk1 in forum Projects, Jobs & Requests
    Last Post: 15-02-2014, 02:16 PM
  3. eBay TB6560 Stepper Motor Driver Boards
    By irving2008 in forum Motor Drivers & Controllers
    Last Post: 07-04-2010, 04:48 PM
  4. DIY Nema23 Motor Mounts
    By Lee Roberts in forum Gantry/Router Machines & Building
    Last Post: 23-08-2009, 06:08 PM
  5. eBay Stepper Motor Drivers from China
    By Mad Professor in forum General Electronics
    Last Post: 20-07-2009, 10:54 PM
