05-06-2016 #2
Yes I know they have been in the business over 30 years and have all sorts they can do rings or plate withsame machine templates a pantograph type arm that also runs from exact same disks and you dial in and move along like an old pressure tape label makers only with drag or power engraver running on the arm or the micro tools on inside or outside of the rings which obviously rotate instead of moving.
05-06-2016 #3
Frank,
have a look over on the CamBam forums, in the Members Projects board (http://www.cambam.co.uk/forum/index.php?board=9.0), for the watch threads (there's two that I know of) by Arie kabaalstra. I know his current machine is reasonably expensive, but that was an upgrade after he started producing watches commercially.
His posts give a good insight into fine work, which I'd think would give you a good insight into the process (design, work holding, tooling etc)
There was also a ring maker over on the mach support forums, however I can't remember his username, and it's been a few years since I noticed him post.
Regarding machines, it'll depend on if you want something turnkey, or to convert something your self. If you want turnkey, of the top of my head I'd suggest looking at a Seig KX1 (Arc Euro Trade sell them), or there's a Swiss company who do a good range of smaller milling machines including CNC options, but I've forgotten their name!Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
The Following User Says Thank You to m_c For This Useful Post:
05-06-2016 #4
im3
doesn't use rotary font discs, that's the dedicated ring engravinbg machine.
At least Google if you're guessing when advising other users!
I own and use exactly the model which the OP requested information on and I'm not answering based on a guess or a Google search, I have actual physical experience using a Gravograph IM3 for diamond drag and rotary cut engraving!
- NickLast edited by magicniner; 05-06-2016 at 10:44 PM.
05-06-2016 #5
Covered Already!
Entry level Probe
By Leadhead in forum Probing, Digitizing & ScaningReplies: 5Last Post: 09-10-2013, 07:55 AM -
help needed going to the next level
By luke11cnc in forum Computer SoftwareReplies: 8Last Post: 20-09-2012, 08:53 AM -
Which end mill to level my acrylic bed?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 18Last Post: 03-02-2012, 02:57 PM -
Which Bench top CNC machine for jewellery etc
By Claymore in forum Machine DiscussionReplies: 2Last Post: 16-11-2011, 08:39 PM -
Level Y Axis
By sfallan in forum Machine DiscussionReplies: 3Last Post: 26-09-2010, 12:52 PM
