    Sorry to chime in but i was wondering if the type of MOD (1 or 1.5) you use is decided by how heavy the gantry ends up being? If so then what is the limit?
    Lives in East Lothian, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Quote Originally Posted by Norgmonster View Post
    The deciding factor is cutting and acceleration forces, and if the chosen MOD size can handle the required torque/forces.
    As part of that you also have to consider tooth engagement, as a larger pinion will have more teeth engaged at any given time so can handle more torque than a smaller pinion.
    Thanks for this info. I'm still working on the designs for my CNC Router so when i'm ready can i ask again?
  1. Replies: 7
    Last Post: 14-04-2015, 02:16 PM
  2. rack and pinion
    By D-man in forum Rack & Pinion Systems
    Last Post: 20-10-2014, 10:42 AM
  3. MOD 1 rack clamps
    By charlieuk in forum Marketplace Discussion
    Last Post: 31-01-2014, 09:07 PM
  4. Rack and Pinion
    By pmcb1011 in forum Rack & Pinion Systems
    Last Post: 31-05-2011, 11:55 AM
  5. Stepper shaft size and pulley bore size problem
