09-06-2016 #2
Hiya,
See what options you've got for file imports, in Fusion 360 for instance it's quite easy to import an SVG file and do a "push-pull" for an instant 3d model.
What you've attached in your post is an image not a drawing or sketch, im guessing its just what you've pulled down from the suppliers website or somthing...
What you want to do is save or export the original as some form of vector graphic, then import it but obviously this probably still means you'll need to redraw it at that level anyway :(.
I'll have a look tomorrow and see what 360 supports and what can be done, if I can pull a flat image in like we need to with this, I don't mind doing that for you on the ones you need and sending them over as dxf's.
Another way you may be able do it, is to save the original as a pdf file, then use an online converter to go "pdf to dxf".
.MeLee
Convert Sketchup drawings to CNC ?
By DaveEP in forum SketchupReplies: 16Last Post: 25-08-2018, 05:52 PM -
Can someone cut my drawings?
By Mikie6024 in forum Metalwork DiscussionReplies: 0Last Post: 23-04-2015, 06:51 PM -
Drawings
By alex wight in forum Marketplace DiscussionReplies: 3Last Post: 06-12-2014, 01:30 AM -
Working / Diagnostic drawings
By manofgresley in forum General ElectronicsReplies: 2Last Post: 04-09-2013, 12:57 PM -
Examples Heidenhain programs with drawings
By hoezap in forum Computer SoftwareReplies: 0Last Post: 09-02-2013, 12:54 AM
