    About Aluminium Nitride:
    Aluminum Nitride or AlN is known as nitride of aluminium, is a grey colored semiconductor material. It was discovered more than a century ago in 1877, but it was not until the middle of the 1980s, its viable engineering properties were discovered. It has high coefficient of thermal expansion and thermal conductivity. Its coefficient of thermal expansion strongly matches Silicon wafer material, resulting to its attractive electronics applications. Its high thermal conductivity makes it an electrically insulating ceramic material.
    Machining & Grinding of Aluminum Nitride
    Aluminum Nitride can be machined into fully dense states in the form of green biscuits. In Green biscuit form it can be machined easily into any complex geometry. However, the sintering process followed during Machining Aluminium Nitride can fully densify the material. It causes the AlN body to shrink 20% of its actual size. This shrinkage makes it difficult to hold very tight tolerances for pre-sintering aluminum nitride.
    So to achieve very tight tolerances, fully sintered AlN is grounded with diamond cutting tools. In this process a very precise diamond coated tools are used. These tools abrade the material until the desired form is created.
    Important Applications of Aluminum Nitride
    • Heat sinks & heat spreaders
    • Silicon wafer handling and processing
    • Electrical insulators for Laser heat management components
    • Molten metal fixtures
    • Substrates for opto-electronic devices and microelectronic devices
    • Substrates for electronic packages
    • Laser heat management components
    • Chip carriers for sensors and detectors
    • Molten metal fixtures and Machining
    • Packages for microwave devices
    • Electronic packaging material
    Aluminium Nitride Machining Capabilities
Name:	Machining Aluminum nitride product  ALN heater jig  - top-seiko.jpg
ID:	18677Click image for larger version.
Name:	Machining Aluminum nitride product  ALN machined part  - top-seiko.jpg
ID:	18678Click image for larger version.
Name:	Machining Aluminum nitride product  Clamp ring - top-seiko.jpg
ID:	18679Click image for larger version.
Name:	Machining Aluminum nitride product  heater substrate  Top-Seiko.jpg
ID:	18680Click image for larger version.
Name:	Machining Aluminum nitride product  heater substrate - top-seiko.jpg
ID:	18681Click image for larger version.
Name:	Machining Aluminum nitride product ALN substrate  - top-seiko.jpg
    I have explained about Machining and Grinding Aluminium Nitride. If anyone have comments or suggestions on this post please feel free to let me know.
Name:	Aluminum nitride product ALN Fan.jpg
ID:	18683   Click image for larger version.
Name:	Aluminum nitride product ALN swirl shaped parts.jpg
    Why not simply post a link to the source of the information you've copied -
    http://top-seiko.com/material-cat/ma...ride-products/
    I don't think we need to know about "The Properties of Tungsten Metal", we use it in the UK for the bodies on high quality darts, it's a British Thing ;-)
    Lives in Marple Stockport, United Kingdom. Last Activity: 22 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    And the point of this to hobby CNC is !! ?
    Quote Originally Posted by ArgeleIntili View Post
    My comment is.....I'm struggling to see what the purpose of this post is??
    Suggestions is......to explain a bit more why you posted this??
    Neil...
    Build log...here
    My comment about Tungsten refers to his post on another forum which appears to have been deleted as it was simply a copy and paste job, predominantly from Wikipedia, it seems ;-)
    It would be simpler to say "Hello, I'm lonely and want to talk", there's fora (the correct multiple for forum) for that :D
    The pattern seems to be that of building a profile with innocuous posts, something often done prior to a massive spamming campaign!
  7. The Following User Says Thank You to magicniner For This Useful Post:
  1. RFQ: Aluminium machining
    By TadasM in forum Projects, Jobs & Requests
    Last Post: 07-02-2016, 01:54 PM
  2. machining aluminium with 1.5kW spindle
    By routercnc in forum Spindles & Drive Motors
    Last Post: 15-02-2014, 02:55 AM
  3. aluminium machining
    By drumsticksplinter in forum Gantry/Router Machines & Building
    Last Post: 15-03-2013, 12:19 AM
  4. RFQ: Aluminium frame Machining
    By mZeles in forum Projects, Jobs & Requests
    Last Post: 27-12-2012, 08:17 PM
  5. Machining Aluminium
    By Steff in forum Metalwork Discussion
    Last Post: 14-11-2012, 12:48 PM
