    Lives in East Lothian, United Kingdom. Last Activity: 3 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    I've got an old electric impact gun I'd like to measure the torque of, however I'm struggling to come up with any kind of semi-accurate method to do so, without spending lots of time and/or money.
    My ideas so far involve threaded rod and a spring stack (suitable spring is the current stumbling block), or a weighted bar (tonight's latest idea, but would need to some work to construct something suitable).
    I do have a couple good torque wrenches for comparison.
    Anybody got any other suggestions?
    You need to keep the system as simple and compact as possible so that the power of the impulse isn't lost to forms of work other than rotary, I'd try
    A big bolt, say M10 with a significant unthreaded length.
    A block of nylon the length of the unthreaded portion of the bolt with a 10mm hole through.
    Slit one side to allow the hole to open up and close down.
    Stick it in a vice and with very short blasts on the impact gun (to avoid generating too much heat) tighten up until you can't move the bolt head then test with a torque wrench.
    A better test might be to start from locked and back off until the first signs of movement and then test with a torque wrench.
    - Nick
    I have tried similar with a M12 bolt and stack of washers, however I suspect there wasn't enough stretch in the bolt/washers to make it accurate enough, as readings seemed to vary quite widely.
    My thought this morning was to get a bit bar, drill a row of holes to accept a row of nuts/bolts, torque them down at increasing torques, then see what the gun can slacken. What I really need to know is how tight a bolt the gun can slacken, as I'm wanting to test fi I can replace it with some form of high torque motor/gearbox.
    You could use a Belville washer as the spring
    I've been on the lookout for something suitably springy, such as some Belleville washers.
    We used to have truck body front mount springs lying around at work, which would of been ideal, but sods law dictates when you need something, you can't find it.
    If I can't find something soon, I'll just have to buy a suitable spring. This is one of those projects that's been continually shoved down the todo list, but is now rapidly approaching the top of the list :-/
    Just found a reasonably priced supplier of Belleville washers, so have ordered some M10 and M12 ones to do some testing.
    I can now rest easy in the fact I'll walk into work tonight and find the other springs!
    I have tried similar with a M12 bolt and stack of washers.
    You haven't, what I suggested is a tubular clutch that you tighten onto a shaft in a vice, very simple and close to a dynamometer, no nut or thread involved ;-)
    I think I just heard a penny drop!
    I'll give that a try when I get time, as well as playing with the springy washers.
    For this you should use the best available friction modifier on the thread to minimise the difference between short sharp impulses and manual torque wrench, Tungsten Disulphide paste is best (but dificult to get, I had to import my stock) as it's coefficient of friction decreases at higher pressures, where Molybdenum Disulphide's coefficient of friction drops,
    - Nick
  1. Replies: 25
    Last Post: 01-10-2013, 05:17 PM
  2. late spring cleaning measuring tools
    By dsc in forum Tool & Tooling Technology
    Last Post: 11-07-2013, 11:04 AM
  3. Digi camera measuring lens threads?
    By graffian in forum General Discussion
    Last Post: 21-10-2010, 02:23 PM
  4. Measuring large items accurately i.e. +-0.1mm
    By alanambrose in forum General Discussion
    Last Post: 13-03-2010, 07:57 AM
  5. Measuring Spindle Runout
    By Lee Roberts in forum Spindles & Drive Motors
    Last Post: 18-10-2008, 11:47 PM
