    Hi Nick
    Thank you for your thoughts. I would like to try and make some aluminium soft jaws like you mention for a job sometime bet it is a great way of holding some parts up there with the best way I would think. I just think for this case the 316 would be a tall order for my machine. I will soon be making some soft jaws for job or another.
    Many thanks
    Steve
    Lives in Plymouth, United Kingdom. Last Activity: 6 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    One clear message to take from that video, something that isn't always apparent to someone starting working with machine tools of any kind, is that you can often spend much longer making a fixture and setting up than you do machining. However, that fixture and set-up time are the difference between a successful job and one that flies out of the chuck or ends up with gouges across the workpiece where it slipped in the machine vice. Of course, a big lathe and 12" 6-jaw chuck also help!
    Here is an example of when a mini pallet maybe of better use:
    https://youtu.be/b2qKy43tJcY
    .Me
    I like the idea, but it is a boring (not a deliberate pun) video. I would bore a big hole in the pallet and use a bullnose in the tailstock to position and hold the workpiece while you clamp it down. You can then check the original hole in the workpiece is central with a dial guage, if it matters that much.
    Rob
  4. The Following User Says Thank You to cropwell For This Useful Post:
  5. #14
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 17 Hours Ago Has a total post count of 802. Received thanks 101 times, giving thanks to others 176 times.
    Guys
    Steve doesn't have a lathe, i asked if he had a faceplate so that i could explain a technique.
  6. #15
    Hi Neale, thank you for your thoughts. I see what your saying 100% I have never made the fixture type in question but lots along similar lines.
    Many thanks
    Steve
  7. #16
    Hi Rob
    I hope your doing OK there mate. Thak you for the thoughts Rob. Perhaps one day I will get a lathe and I look forward to that day!
    All the best
    Steve
  8. #17
    Thanks mekanik, perhaps one day I will get a lathe. That would cause another project extending the workshop!
    Many thanks
    Steve
  9. #18
    I think your Triac should manage it, my little benchtop CNC would, the trick is to get your tooling, feeds & speeds, DOC and cutting lube right.
    - Nick
  10. #19
    - Nick
    Hi Nick, thank you for the thoughts. I think I would get myself into a whole world of hurt with 316. I am don't know much at all about CNCing and nothing when it comes to 316. I have made some parts out of plastic that worked well but I harldy ever get to use my machine and does'nt help with getting to grips with things. Like you say you would need to know about the tooling feed and speeds and I could write what I know on the back of a postage stamp!
    Many thanks
    Steve
  11. #20
    Steve,
    316 isn't anything like as scary as a lot of people make out ;-)
  1. Triac PC CNC Machine For Sale
    By Paul in forum Classified Ads, Buy, Sell & Swap
    Last Post: 16-05-2016, 09:35 AM
  2. eBay: Excel machine vice taken off a Denford Triac
    By jamesgates1000 in forum Items On eBay UK
    Last Post: 20-10-2015, 07:30 AM
  3. Replies: 22
    Last Post: 07-06-2015, 10:25 PM
  4. NEW MEMBER: CNC wanabee I guess.
    By aliasant in forum New Member Introductions
    Last Post: 07-11-2014, 10:34 PM
  5. FOR SALE: Denford Triac Bench Milling Machine
    By Binary in forum Items For Sale
    Last Post: 17-10-2014, 09:06 AM
