  1. #24
    Quote Originally Posted by Slixxor View Post
    When did I make that claim? This is my first build and I don't see that claim made :/? I think you grossly underestimate my realism..
    Sent from my SM-G920I using Tapatalk
    Crossed purposes wasn't talking about you with that statement.
    I just like the way you assumed I needed to be more careful. What exactly gives you the impression I haven't been?
    Because I'm not blind and can see there's been no machine work done on any of those surfaces or any thought regards rails being on same plane etc.
    I've never yet seen piece of angle iron that is perfectly flat or 90deg and you are bolting straight to the face of one.
    Then we have the heat put into the metal which can clearly be seen. You can Stitch it with pigeon Shit and beat the shite out of it all you like but it will still be warped or twisted in some way unless you take other steps to correct it.
    All these little things will bite and like I've said your lucky your using round rail. Profiled linear rail would just not tolerate this level of in accuracy and bind up solid.
    Edit: Just to be anal and prove my point look at this picture and tell me whats wrong.?
  1. BUILD LOG: Desktop size steel welded router 3 axis
    By Tom J in forum DIY Router Build Logs
    Last Post: 28-03-2017, 09:36 PM
  2. Z-axis huge slack / beginning a conversion
    By diy-john in forum Gantry/Router Machines & Building
    Last Post: 04-03-2012, 10:26 PM
  3. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
  4. CONVERSION: Buget Warco Major 5 axis conversion
    By Tweaky in forum Conversion Build Logs
    Last Post: 07-10-2010, 04:26 PM
  5. Ron Steele Mini Lathe CNC Conversion - Z Axis Leadscrew?
    By No1_sonuk in forum Lead Screws, Nuts & Supports
    Last Post: 17-05-2010, 12:47 PM
