Thread: Hypertherm plasma cutter advice.
hi all , does anyone know what is the bigger size hypertherm plasma you can on 240v..
i know they was a hypertherm rep that used to use this site.
cant remember there name, or if they are still here.
not sure if its the powermax 45 or 65. ?
cheers all.
	14-06-2016 #2
The 65 is available in single phase input, at 240v the input current is going to need some special provision.
	14-06-2016 #3
i do have 240v 32amp sockets.
would that be enough....
cheers.
	15-06-2016 #4
I just googled hypertherm, one of the first page of links is the UK distributor, they have PDF spec sheets, there are two types of amp ratings for single phase machines, I don't know what the abbreviations stand for,but for 240v they are twenty-odd amps and forty-odd amps.
	15-06-2016 #5
To run a powermax 65 from single phase 230v you would need around a 44 amp supply. A powermax 45 will need around a 30amp supply at 230V.
	16-06-2016 #6
right cheers for the reply..
so im ok currently to run the PM45 on a 240v 32amp socket.
but to run the PM65 i would need to upgrade the cable to 10mm T&E.
and MCB to 50amp, and the socket to a 240v 63amp.
EDIT. wow have you seen the price of the 240v 63amp plug and sockets OMG.....Last edited by T0rnado69; 16-06-2016 at 01:28 AM. Reason: add info
Brit made plasma THC for Hypertherm / Mach3 users
By stirling in forum Manufacturer NewsReplies: 3Last Post: 13-02-2013, 09:58 AM -
FOR SALE: CNC Plasma Cutter For Sale
By billm in forum Items For SaleReplies: 6Last Post: 17-07-2012, 07:50 AM -
Which Plasma Cutter to buy?
By AndyG in forum General DiscussionReplies: 7Last Post: 02-12-2011, 09:34 AM -
First Plasma Cutter
By antsals in forum Plasma Table MachinesReplies: 3Last Post: 16-05-2011, 07:58 AM -
Hypertherm Plasma Cutting Systems
By Hypertherm John in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 04-03-2011, 02:46 PM
